March 2, 20224 yr Hi to all this is my first post on here my brother has bought an 02 xvs650 dragstar which the previous owner has started to Bob. He is having an issue where he charges the battery and when he goes out for a run the battery is not holding the charge and running flat. My thoughts are the stator but is there any known issues with the charging system on these bikes, or indeed any other potential reason for the battery not charging while riding. Thanks for taking the time to read this I'm hoping someone can help Edited March 2, 20224 yr by Johntracer7 Title added
March 2, 20224 yr Moderator The obvious answer would be a duff battery. But you'll want to check for shorts too... P.S. Check the main earth.
March 23, 20224 yr Hi, I have a 2003 that’s been bobbed. The stator went on mine. Replaced and all good since then.
