February 27, 20224 yr since battery connected in reverse XJ600 Pre diversion runs but over charges battery and kills regulator - add advise to fix please.
March 6, 20224 yr Moderator 2 hours ago, mike1949 said: Introduce yourself in the newbie section? After the above, and solving the problem, put an in-line fuse in the negative terminal (I've found it saves a lot of problems for all sorts of electronics!)...
