78 dt125 no spark. Switches are good. Positive battery terminal to the frame is a dead short. Lost spark while riding. Is this a compensator amd points issue?
Battery has nothing to do with the engine running on a dt, It will literally need one wire from the mag to the coil to run. Bought a field bike for spares in just that configuration.
If you have a good plug, coil and lead then continuity down to the mag the only fault there will be the condenser or the points need adjusting or are fouled.
I myself used to run the condenser outside of the mag on dt's i have had in the past, may reduce efficiency slightly but save a whole lot of ball ache when they fail, and far easier to change out on a regular basis saving the points burning through a weak condenser. Condensers do fail, likely the weakest 'point' of the system.😁
May just be a bit of fluff in the jaws of the points.
  • 3 weeks later...
I replaced the condensor but still no spark
The black and white or yellow i cant tell that comes out of the case if you test that wire to ground and put it on dc20 or ac20 it has 0 voltage
hi there, the output of the flywheel/magneto is AC...but....if it's not running...then you will only be able to test the output when you kick it over, don't expect a constant reading as the Flywheel will only spin a few revolutions.
What model is it DT125 ?E ?F  ?1F9. You mention "compensator" . In the UK it's referred to as a condensor,  so is this a US or UK or another Icelandic bike?
