Posted August 1, 20214 yr Hello, I am looking to replace blocked injector on my YBR125 (2007 model). It appears that YBR125 injector is far more expensive compared to YZF125 or WR125. Could anyone please help me with the following: 1. What is the flow rate of original injector fitted in ybr125 (2007)? 2. Can I use slightly higher flow rate injector? 3. Are YZF or other Yamaha 125 injectors (with two pin connection that look same as ybr125 injector) actually same in physical dimension? Thanks in advance.
