Posted July 30, 20214 yr Moderator So... It's raining... I've got rain wear, but it would appear that there's pinhole leaks in the trousers (probably from putting them on and taking them off) around the crotch somewhere. I'm going to put this down as being one of the problems of rubberised clothing. So, the question is: Does anyone make non rubberised wet wear? Gortex or just simply better quality maybe?
July 30, 20214 yr Author Moderator 5 hours ago, finnerz89 said: Goretex for me Do you have any particular examples / suggestions? 3 hours ago, jcr said: i dont ride in the wet. thats what cars are for! There's something liberating in riding in the wet (so long as your knackers stay dry!)... Yes, you stay dry and warm and can have a peaceful fag in the car, but it's just not the same! Trust the rubber..!
July 31, 20214 yr I've got some Rev-it 2 piece textiles. They're the laminated outer rather than a lining so the water doesn't soak into the fabric
August 1, 20213 yr Going back a lot of years SB I found that when going to and from work I had a pair of waterproof leggings where the seams especially around the crotch area were "welded" rather than stitched and never had any problems with as you so eloquently put it "soggy knackers" Mike.
August 1, 20213 yr Author Moderator The seams of mine are internally taped, however, I think I've found the problem, part of the tape is loose. What I need now is some rubber cement! I still want some better waterproofs though.
August 2, 20213 yr 7 hours ago, Snakebite68 said: The seams of mine are internally taped, however, I think I've found the problem, part of the tape is loose. What I need now is some rubber cement! I still want some better waterproofs though. The best over trousers I had were richa rain warriors
November 1, 20213 yr I've got some Rev-it 2 piece textiles. Mobdro Edited November 1, 20213 yr by brewmaxwell649
November 1, 20213 yr Author Moderator Oh, I've got textiles (RST 3 piece). They work pretty well, but there's no substitute for decent waterproofs lol
November 1, 20213 yr i"v found only the boiler suit type with the diagonal zip works, as the zip is offline with the crotch area,💦💦
December 4, 20213 yr Author Moderator On 12/4/2021 at 1:33 PM, inshashare said: The seams of mine are internally taped, however, I think I've found the problem, part of the tape is loose. I'm thinking... Bot... I wouldn't click on those links..!
