plug cap prices
had another play today, the bikes now running properly.
it was my incompetence that caused the problem.
the plugs come preset by NGK. i misread the  feeler gauge and set the gap to 0.2mm.
set the gap to 0.6mm and bikes running properly.
i am now a happy bunny.
thanks for all the help folks
just need some good weather now so i can go out and play.
Still doesn't explain the nearly 2mm gap on the old plugs! lol
Bike works!
Get out there (this is what rain gear is for)!
the old plugs were gapped correctly at 0.6. i was reading the imperial side of my feeler gauge.
im a right numpty!
i only ride in dry weather theses days, southern softy that i am:D
Excellent news bud, glad to hear you're up and running.
Aaah!
Yes, but the rain is warmer down there, you should try it up here in Gods Country! :D
Out today,  15 degreees ,,,hottest yet,,  i was on the 550.. mates on  Yds7
May be an image of motorcycle and outdoors
it rained for most of the day here.
ive replaced the fork oil and lowered the yokes 5mm on the forks since i last rode the bike.
one of the forks had a 20mm larger air gap than the other and the springs are at their service limit.
hopefully ill notice a difference in the handling when i do get back out.
I have put spacers in a TS250  before to cure  sagging  springs ,, made outa 22mm copper  pipe ,
On 5/18/2021 at 8:27 PM, blackhat250 said:
i will probably put new springs in if i do it again
