Posted April 6, 20214 yr I have issues with my yamaha xj600, engine isnāt running. Spark plugs are new and have spark, when i screwed them out of motor block they are wet with fuel. Checked fuel lines, cleaned carbs but nothing. Then i pour fuel directly in carbs the. Engine starts to sneeze and shoot the flames but thats all. Before winter get engine running but for short time with full trotil and got maximum 1500rpms
April 9, 20214 yr Has it been sat with fuel in the tank and carbs over a long time? cos if it has then your carbs are bunged up with old fuel and will need to come off for a through clean. Try some "Easy start" up through the air filter to see if it fires, if it does then you have a solution to the problem, lot's of cleaning. Try carb cleaner and sone fine wire through the passageways inside the carb. RemoveĀ the jets and blow them out and if you can find a carb refurb kit which will help freshen up the thing.
April 11, 20214 yr Take out the plugs & leave for a day or two,,sounds like your floodedĀ out,Ā check your oil level,,if its High,,it be fuel in it,,, change it,,, Ā
May 8, 20214 yr Author It sneeze only when i put fuel directly in carbs without that engine turns without smoke or anything
May 9, 20214 yr Author 3 hours ago, Snakebite68 said: I have no idea about carbs, what are we looking at? That my friend is screw for main jet and its broken off
May 9, 20214 yr Moderator Well, that's not good, I'm assuming the engine hasn't ingested it? All I know about the Thunderace Carbs is that the emulsion tube isn't replaceable... NOT that I know what an emulsion tube is...
May 10, 20214 yr Author 8 hours ago, Snakebite68 said: Well, that's not good, I'm assuming the engine hasn't ingested it? All I know about the Thunderace Carbs is that the emulsion tube isn't replaceable... NOT that I know what an emulsion tube is... Everything is okey just need to find new screw and changeĀ it. Screw comes at float chamber so it cant get in engine
