March 31, 20214 yr Hi I have the code 19 on my ybr125 2009 so I have changed the ignition and the ecu and the coil and the spark plug i have checked all the wiers and all are ok and I'm still getting the code 19 can someone please help me with this also I bypass from the + side of the battery to the horn connector and the bike starts but when I go to put it in gear it cut out
March 31, 20214 yr Moderator Fault code 19 - No signal from ignition to ecu Have you checked the kickstand kill switch?
April 3, 20214 yr Author On 3/31/2021 at 10:26 PM, Snakebite68 said: Fault code 19 - No signal from ignition to ecu Have you checked the kickstand kill switch? Yes I have checked the switch and it still works
