Yamaha Majesty YP250 - Exhaust hanger main bush has play
Hi,
Looking for some knowledge on my Maj. 250's exhaust hanger main bush (through which the rear wheel spindle
passes).
For recent MoT (new rear tyre) I removed tailpipe and hanger, and then noticed that the bush had quite a bit
of movement / play where the rear spindle goes through, - links below to vids I put on Youtube.
Both sides move against the rubber, - the fixed metal bush, and the removal one on the other face.
Simple question - anyone know if it's designed to have some movement, or if it's just worn out?
Thanks!
https://youtu.be/y4GF1Fb5BHw
https://youtu.be/EOB1UmcfPkk
Edited by Tristan Go
Hi,,,i think it will designed to take impact,,  Did you know the Majesty was a modified  TY,   by Mick Andrews & John Edeurdo   ,  its in the name,,M.AJ.E,sTY
21 hours ago, Tristan Go said:
These videos appear to be designated 'private'...
Thanks for letting me know Snakebite68, - I've changed their settings in Youtube, - should now be watchable.
Would appreciate your thoughts.
Many thanks.
Not knowing the bike, I'm not entirely sure what I'm looking at.
But the 2nd video makes it look like a standard bearing with a seal over it...
See if the seal comes out??? lol
Thanks!  I'll have a go later this week and post back. 👍
looking at this fiche, its a bearing
https://www.fowlersparts.co.uk/parts/4012594/yp250-5sj2-2002-060-a/rear-arm-suspension
should be able to buy from a bearing supplier if you can get the number off the bearing it self.
heat up the alloy first and press out straight. oil seal will pop out using a small pry bar
93306-302YK
