Hi all, my bike wont start after i clean up my carb. i just dissamble it,clean and put it back. The fuel pump sound ok, the starter crank ok but it won't start.....please someone help me???
Look under the tank and double check to make sure you haven't trapped or pinched a fuel pipe
Turned the tank tap back on?
I've fallen for this...
Squirt Easy start or brake cleaner in intake,,  if it offers,, you know its fuel related,
i already diagnose that there no spark for both cylinders, and do a resistant check up....it was the pickup coil/pulser coil huhu
