Posted May 30, 20205 yr Greatings from DenmarkĀ i have issues with my 21 year old yamaha 600 Fazer. it is almost like my engine stutters, when arround 3000 rpm it stalls and dies when i give it more throttle.Ā Ā Anyone who have solved same issue? Ā
May 31, 20205 yr Not much information to go on. You dont say how long youve had the bike, when it was last serviced, when it was last used, but it sounds initially like carburetors require cleaning. You need to check plugs for sparking, exhaust downpipes for heating, if the fuel is old, change it.
June 1, 20205 yr Author On 5/30/2020 at 7:55 PM, blackhat250 said: Sounds fuel related.....or filters.. have tried to replace the fuel filter no succes šĀ Hi sorry for the missing information i have had the bike for several year and drives it all year. last service was around 45.000 now 60.000 today i changed the fuel filter, wiht no result other than when i give it throttle it dies.... Ā Edited June 1, 20205 yr by cartin
June 1, 20205 yr Author 3 hours ago, cartin said: have tried to replace the fuel filter no succes šĀ Hi sorry for the missing information i have had the bike for several year and drives it all year. last service was around 45.000 now 60.000 today i changed the fuel filter, wiht no result other than when i give it throttle it dies.... Ā Ā i emtphied the tank and screw loose the filter and cleaned this aswell but still no tork. I have ordered new spark plugs airfilter, so iĀ“m exited to see if this has influence, and i have also adjusted TPC to the right level...
June 1, 20205 yr Moderator check inletĀ manifold for cracks and leaks by spraying easy start around there to see if the revs rise.
June 6, 20205 yr Author On 6/1/2020 at 7:58 PM, drewpy said: check inlet manifold for cracks and leaks by spraying easy start around there to see if the revs rise. i can“t give the bike revelations, the engine dies when trying to throttle up
June 6, 20205 yr Moderator 1 hour ago, cartin said: i can“t give the bike revelations, the engine dies when trying to throttle up didn't say you need to throttle up
