Hello everybody!
I have a Yamaha X-max 125 (2010). The problem is I can't start it up. Maybe you could give me some ideas what to do?
So, the symptoms are that the starter works but there is no spark.
I also noticed that when I turn the key to ON state, I can't hear the fuel pump as I used to. Also the immobiliser diode doesn't light up at all.
Can you give me some hint what I could do to diagnose this problem further?
Could that be a failing immo? Maybe some water got into it? Or rather is it the ECU?
Or maybe (hopefully) there is something else I could check/fix?
