Posted February 11, 20205 yr Some labels have fallen of my loom the neutral warning light an oil light share a wire but I can't remember if its Brown or black It's on a 1989 DTR but I assume otheryams are the sameÂ
March 28, 20205 yr Author The neutral an oil light share both share a wire but I m not sure if its An earth ( black ) or a live ( brown ) From what I can work out this wire comes from either the kill switch or front brake light switch ( on a DTR) Trouble is I ve replaced some wires an now I have a random black wire with brown tracer stripe that's not on the Diagrams So I need to know the correct colour wire the two warning lights share ? An where it should come fromÂ
March 29, 20205 yr Moderator Don't forget the oil light comes on with the neutral light as a way of showing the bulb works properly.
