Trying to get a spark and crank with start button. Gauges and lights only light up with main switch in center position.. is this the run position? Also, is it necessary for the turn signal wiring to be complete to get a spark and power to the solenoid? There is a solid yellow wire that went to the dimmer, does this need 12v for the bike to start? Horn does not work either. Please attempt to help me. I am using an aftermarket left handlebar switch.
From the harness I have
Pink- horn - I have power here
Blue/Yellow- headlight dimmer switch power input - I have power here
Green- headlight low beam
Yellow/black- headlight high beam
Yellow- unknown
Blue-unknown
Dark Green-right signal
Brown/white-turn signal switch power? I have power here
Dark Brown- left signal
Yellow/red- unknown - I have power here
black-unkown
From the switch I have
Power input , High & low - headlight
Turn signal power, left & right -turns
And 2 wires for the horn
Edit: have spark now and cranks with button, just gotta figure out this mess
Edited by Solara
