July 19, 200619 yr HI I HAVE A UK SPEC 1997 THUNDERCAT WHOOSE FRONT BRAKE CALLIPERS HAVE SEIZED. I'VE BEEN TOLD THIS IS A COMMON PROBLEM WITH THESE CALLIPERS AND THEY WILL NEED REPLACING, AND HAVE BEEN RECOMMENDED FAZER CALLIPERS AS A BETTER ALTERNATIVE. CAN ANYONE CONFIRM IF FAZER FRONT CALLIPERS WILL FIT MY CAT AND IF SO ANY PARTICULAR MODEL/YEAR OF FAZER? OR DOES ANYONE KNOW ANY OTHER WAY TO CONFIRM THIS BEFORE I SPEND MY HARD EARNED £'S ALL ADVICE AND SUGGESTIONS VERY WELCOME. THANKS
August 1, 200619 yr Moderator they are EXACTLY the same calipers take them off, pump the pistons out and give them a real good clean using brake fluid, replace the seals and re-bleed the system...piece of piss and a whole lot cheaper
August 2, 200619 yr Author they are EXACTLY the same calipers take them off, pump the pistons out and give them a real good clean using brake fluid, replace the seals and re-bleed the system...piece of piss and a whole lot cheaper Thanks alot for the advice Appreciate it. Cheers
