THUNDERCAT FRONT CALLIPERS
HI
I HAVE A UK SPEC 1997 THUNDERCAT WHOOSE FRONT BRAKE CALLIPERS HAVE SEIZED.
I'VE BEEN TOLD THIS IS A COMMON PROBLEM WITH THESE CALLIPERS AND THEY WILL NEED REPLACING,
AND HAVE BEEN RECOMMENDED FAZER CALLIPERS AS A BETTER ALTERNATIVE.
CAN ANYONE CONFIRM IF FAZER FRONT CALLIPERS WILL FIT MY CAT AND IF SO ANY PARTICULAR MODEL/YEAR OF FAZER? OR DOES ANYONE KNOW ANY OTHER WAY TO CONFIRM THIS BEFORE I SPEND MY HARD EARNED £'S
ALL ADVICE AND SUGGESTIONS VERY WELCOME.
THANKS
they are EXACTLY the same calipers :rolleyes:
take them off, pump the pistons out and give them a real good clean using brake fluid, replace the seals and re-bleed the system...piece of piss and a whole lot cheaper :P
Thanks alot for the advice
Appreciate it.
Cheers
