September 4, 20196 yr Starting a restore project on a 1979 XS750 Special. So far I've mostly cleaned everything under the seat and tank. I removed carbs today and found a great deal of oil in right side of triple. That means I have a bad petcock on that side allowing too much fuel to enter and flood chamber bringing oil back to the carb. No problem since I plan on rebuilding them anyway. Should I rebuild carbs or can I get away with just cleaning them? Also ordering starter and flasher relays since I'm having electrical issues with lights and etc. Just installed a new battery cover/fuse box. The old one had been removed and was direct wired in the most horrific way imaginable. I figured it was because they bypassed bad relays. Any thoughts on these subjects greatly appreciated.
September 4, 20196 yr Hi mark. i mind of the xs750 when new, mate bought one,, shaft drive too, it was our first delv into Four strokes, What type of carbs ? , if its not diaphrams i would just ultra sonic clean them, ,,.Performance aint startling , a well kitted Lc350 will out drag yeh ,,😎
September 5, 20196 yr Author 20 hours ago, blackhat250 said: Hi mark. i mind of the xs750 when new, mate bought one,, shaft drive too, it was our first delv into Four strokes, What type of carbs ? , if its not diaphrams i would just ultra sonic clean them, ,,.Performance aint startling , a well kitted Lc350 will out drag yeh ,,😎 I decided to rebuild them. No since chancing it over $60. Also switching flasher and headlight relays to LED. I plan on riding late at night when there's less traffic here in the foothills of North Carolina. I want to be seen from all angles so I'm going to LED everything. Even thinking about LED's on my helmet. 😁
September 5, 20196 yr N/c , i "ve been there ,Elizebeth City, and Cape Hateras , aint that big hurricane about to hit you lot ,?. you be up Raleigh way ,eh ,
September 7, 20196 yr Author On 9/5/2019 at 3:56 PM, blackhat250 said: N/c , i "ve been there ,Elizabeth City, and Cape Hatteras , aint that big hurricane about to hit you lot ,?. you be up Raleigh way ,eh , Yeah, a lot of friends in family had some damage but everyone's safe.
