Posted August 2, 20196 yr Hi,as above have pods currently but will be going back to the standard airbox for a miriad of reasons... My bike is the last of the 58l model,uk spec and is a 1991 So many contradictory info on what was the standard jet size etc so could someone give me a pointer. Thanks. Nev
August 2, 20196 yr Does this help? Found it on http://xjbikes.wikidot.com/carb-specs Good luck. Years & Models: XJ900 model 58L Carb Manufacturer: Mikuni Carb Series: BS36 Carb Model ID: 58L00 Main FUEL Jet Size: #107.5 Pilot FUEL Jet Size: #40 Main AIR Jet Size: #45 (non-removable, in carb throat) Pilot AIR Jet Size: #160 AIR COMPENSATOR Jet Size: not used Starter FUEL Jet Size: #35 (non-replaceable, in float bowl) Main jet NEEDLE ID: #5FZ62-3 Main needle JET Size: #Y-0, style #318 (the main needle JET is also known as the "power valve" or "emulsion tube"). Float Valve Seat Size: 2.3mm, uses a shorter float valve needle and the needle is clipped to the float arm. Fuel Level in float bowls: 5.0mm +/- 1mm (.118" +/- .039") Idle RPM's: 1,050 rpms Although not part of your carbs, your valve clearances should be considered as part of your "intake system", so here are those specs, too. Note that valve clearances should be measured with the engine "cold", meaning 70-degrees Fahrenheit or less: Valve Clearance Intake: 0.11 - 0.15mm ( = 0.004 - 0.006") Valve Clearance Exhaust: 0.16 - 0.20mm (= 0.006 - 0.008")
