400 xs. Replace regulator and rectifier with one unit
1980 400 XS.  I have a seperate five wire regulator and three wire rectifier.  If I want to replace both with one unit do I just wire the old rectifier (three white, one black, one red), to new combo unit and then old regulator, ( black, green and brown), to the new unit?
So I am just rewiring two units into one.  Thanks for reading.
There are  only two wires for the regulator on the new combo unit, the old one has three.  Do I ground the green and splice the bnlack and brown?
Edited by scott froid
update information
You sure you have the right one?
there were 2 types of xs400 the Dohc had a different charging system than the sohc
