Trying to debug a starting problem. Not getting any response at all. Following the Clymer's manual I bypassed the starting circuit cut-off relay and supposedly got the correct behavior
from the starter solenoid. It says to check the relay, it's "behind' the solenoid. Nowhere in any of my manuals do I see a picture of one...is it a little metal cubic 1" box??
Starter is fine, battery okay, solenoid okay, neutral light is on, and
the starter button fires....I get nothing, occasionally a 'click'
You can hear the solenoid click and sometimes you can hear a whining noise where the motor is trying to start, but it won't turn over.
thanks
  • 2 years later...
got the same problem man if you find out let me know
Starter motor brushes ?
A quick check with a good battery & jump leads, neg to ground on the engine, pos to the starter side of the relay, if the motor turns thats OK
Bad solenoid? ( it may click but the contacts inside may have burned out )
Check by using a jump lead to connect both terminals ( bypassing the solenoid ) - if the motor spins up the solenoid is bad
Check the fuse contacts and any earth leads - a bad connection can sap a lot of power due to the high resistance
Had this same issue with my 550 Seca once....ended up finding the Starter Circuit cut-off relay under the frame backbone,
above the coils. ;)
Yanked the relay & jumper-wired the connector to complete the circuit.
Best of Luck with it.
