April 8, 20196 yr Evening Getting a new chain and sprocket this week so just wanted to know if there’s any specifics in regards to what size sprockets to go for or shall I just go for a standard setting if I did change amount of teeth of either sprockets is there any benefits or downsides ???
April 10, 20196 yr If you go up 1 on the front ,you"l get better mpg,, [ lower revs at cruise speed ] but loose a little excelleration ,
April 11, 20196 yr use gearingcommander.com to map specific combos and see if a different length of chain is required.
April 11, 20196 yr 20 hours ago, blackhat250 said: If you go up 1 on the front ,you"l get better mpg,, [ lower revs at cruise speed ] but loose a little axcelleration , Yup. The FJ was slightly high in revs and MPG at cruising speed. But with torque to burn on the tank I went up 1 tooth on the front. The improvement was very noticeable. Did not need to change from the standard chain. Edited April 11, 20196 yr by DutchFJ1200
April 12, 20196 yr On 4/8/2019 at 9:43 PM, Morillo said: Evening Getting a new chain and sprocket this week so just wanted to know if there’s any specifics in regards to what size sprockets to go for or shall I just go for a standard setting if I did change amount of teeth of either sprockets is there any benefits or downsides ??? In all honesty Morillo, we've all tried different combinations of sprockets. I.E. faster acceleration but slower top speed, or slower take off from lights but higher top speed. The best thing to do is leave it to the manufactures specs. Believe me, they know best. Edited April 12, 20196 yr by mike1949
