XJ6 headlamp bulb, replaced, fuse ok, not lighting
Hi
The headlamp blew on my XJ6. I have removed the old bulb and replaced with a new H4 type. The bulb does not light. I have tested the voltage at the bulb connector that pushes into the back of the bulb and there is no voltage.  I have tested the terminals into which the bulb fuse fits and there is no voltage there. The 20A headlamp bulb is not broken. All other electrical components seem to work ok. The bike starts fine. Does anyone know where else I check to see if some wiring connection is loose to explain why the bulb doesn't light?
Regards,
Clive
