This post is 2140 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Hi all,
my MT 03 (2007) has got a fuel leak. The stuff is dripping out from around the fuel pump bracket when parked up so I'm looking for advise on what is the best sealant I could use.
Thanks
Tim
It's not going to be quick fixed with sealant.
A gasket or o ring has gone and you will need to replace it. Fuel is too expensive and dangerous to waste.
Believe it or not, about ten years ago I had a fuel leak from the bottom of the tank whilst at work.
Blu Tac got me home til I sorted the problem out.
Mike.
