Wheel noise
Hi guys there this tickling noise coming out from rear wheel as you can see in the video i dont no what it is i can feel in my left foot peg too when i am riding slow.if you guy know what it is before i take it to workshop. Thanks
Sent from my SM-G950F using Tapatalk
Check your chain first. Either tension or you could have a couple of dry links.
To me it sounds like the chain isn't running well over the front sprocket which would cause vibes in your left foot.
As above, check the chain for stiff links. Also check the sprockets for hooked teeth, make sure the front sprocket is secure on the splines and the wheel bearings for wear. Is that a fazer? Early fazers had a problem with the front sprocket coming loose, they replaced them with a deeper one
