Yamaha YBR 125 2007
Hi I have a error code 19 (no signal from ignition to ecu) on dashboard. I have replaced the ignition switch as old one was faulty.  Previous to this I had a error code of 46(power supply to FI system) which I had to change -
Blocked fuel injector
ECU unit
Stator Magneto (burnt)
Replaced Battery as old one was not holding charge
Checked black/white wire traced from ignition to ecu which is fine on continunity
I have no spark so waiting for a replacement ht coil to see if this is the problem. I have changed the ht coil still not working. Can anybody let me know if could be wiring loom a break somewhere?
Edited by Ads00
