Bewls88 Posted October 12, 2018 Posted October 12, 2018 I have a random problem as the title suggests. I bought a sr125 recently and knew it had an issue with the speedo not working.. but the bike ran great so was happy. I've realised since riding around the block to figure out whats going on that the odometer is actually going backwards?? How is this possible? The speedo cable is fine if i turn the cable then the speedo works and turn it for long enough the odometer goes up correctly but for some reason my speedo drive is running backwards? Has something been set up incorrectly on the front end? It's a 94 model with disc brake at the front only. Any input would be greatly received.. Tia
mike1949 Posted October 12, 2018 Posted October 12, 2018 Hi Bewls88, First of all welcome to the forum. I personally can't answer your problem. I'm sure that somebody on here can. What might help you to get an answer is to first of all go to the "newbie's section" and introduce yourself. A lot of regulars don't like "one hit wonders". Once you have done that, then go to the appropriate section, in your case I would suggest the workshop. Hope this helps. Mike.
Moderator Airhead Posted October 13, 2018 Moderator Posted October 13, 2018 interesting, post a picture of the bike
NE0 Posted October 14, 2018 Posted October 14, 2018 (edited) I've seen this once before when a mate put on a different wheel from another bike, whilst it fitted, the gearing for the speedo drive was on the opposite side and ran in a different direction. Edited October 14, 2018 by NE0 1
