October 8, 20187 yr Hi. I'm greeting everyone on this club. I will need yours help. I have tdm 850 3vd use it 10 months but now there is no spark. I've check everything and was left only cdi unite. I will be grateful for chance to check my cdi unite on your bike. It is 10 minute of your time. I will come with good bear ?. Many thanks for help.
October 9, 20187 yr Drewpy has a TDM,,, he"l be along soon,, wheres are you ,? fill you profile in ,,,
October 9, 20187 yr Moderator the mk1 has a wasted spark system as opposed to the 4TX have you checked cleaned the connections to the ignitor box? these go green with damp and age? did you check, side stand switch? bypass it just in case its faulty. that'll do for now till you report back
October 9, 20187 yr Author I've check everything. Sensor on crankshaft, coil, high voltage waiting, main switch, cut off switch, replace brown cable from electrical system and all connection. Was left only cdi but I allredy bay it second hand and was the same. I still don't have site that unit was good. Thanks I live in birmingham. West Midlands. Thanks. Sorry for writing mistakes but my phone is very mad. Thanks for help.
October 9, 20187 yr Improbable that both cdi boxes are goof, i would take of coils and clean the frame where they mount,, it has to be a connection or EARTH [and are you shure its just your fone thats Mad, -? pmsl laughing at that,,,
October 9, 20187 yr Moderator did it just stop working or after you did something to the bike? There's lots of info over at http://www.carpe-tdm.net
October 9, 20187 yr Author Bike losing voltage at the moment when you press starter button. After few seconds voltage go back and ONE spark com's but nothing after. Coil have right resistance. I return brand new high coil back to shop after when wasn't any better.
October 10, 20187 yr Moderator That its still there or its output? Please! you have already checked it. Well your first post said you had checked everything, does it run? no. So you missed something and you want suggestions, that's why your here. If your just shutting people down I will leave you to it.
October 12, 20187 yr Author I don't now what you mean "shutting people down" but I'm not. I'm here because from this what I now I've checked everything. Possible I missed about something. From my point only cdi unit left. It isn't my fouls that I can't bay brand new cdi. Maybe if I can and nothing will change I can say "yes I missed something". We can only support by used parts mostly. I am hire to find someone why live locally and help me to check my cdi. I think is simplest way to clarify cdi unit and not waist the time for checking good part again and again. 2 months I trying to fix this. I have nightmares about it all ready.
October 17, 20187 yr Author No. I use other battery for starter and other for the rest. Same symptoms
December 3, 20186 yr Have you checked the low tension supply to the coils ? also have you cleaned all the earths and the multi connectors throughout the bike faults normally occur with those with poor connections
