Throttle cable stolen?!?
Raj
This post is 2247 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Long story short, for some unknown reason the throttle cable was stolen from my Yamaha Mt-03. I'm having trouble installing the new one as I have no idea where the cable was routed. Is it common for them to go under the fuel tank?
Thanks, Raj
Well usually they go out from the throttle round the head stock and under the front of the tank then dip down onto the top of the carb or injector connector. BUT don't force it whatever you do, it must be a smooth run from end to end without any kinks or severe bends. Get it right no problem get it wrong and you can't shut the throttle, not something to fuck with if your not certain, go to you local bike shop and get them to do it if your unsure.
PS say hello in the new members section, it helps if you introduce yourself. Just sayin..!
