June 20, 20188 yr Moderator working from memory the shim will allow the swing arm to be totally free from binding when the swing arm pivot is torqued up to spec, you have to remove the damper and wheel and have the bike supported to test that, then just left and release the swing arm and it should move freely
June 21, 20188 yr Author HELP. Trying to locate a Pivot bolt - Google has let me down. Anyone know a supplier?
June 21, 20188 yr Is this where the shock attaches too at the top of swingarm or the bolt that connects the swingarm to the frame?
June 21, 20188 yr Moderator 4 hours ago, Simon46 said: Is this where the shock attaches too at the top of swingarm or the bolt that connects the swingarm to the frame? to the frame Si
June 21, 20188 yr Author As Airhead says it's the bottom one. 12mm dia, approx 200mm long (excluding head), approx 16mm of thread. The one which connects to the bottom of the shocker on mine is just a clevis pin with a split pin stopping it from coming out (in addition to the tight fit).
June 21, 20188 yr The guy had 3 left when I rebuilt my 175mx. Let me see if I can find him. BrbSent from my G8141 using Tapatalk
June 21, 20188 yr The part number you need is 2N4-22141-00 and is common to over 323 machines. Just a case of looking for one for another model https://www.cmsnl.com/yamaha-mx175-1980-a-usa_model8746/shaftpivot_2n42214100/ i think you have to log in to see the full list. https://www.bike-parts-yam.com/yamaha-motorcycle/assignment_spare_parts/2N4-22141-00 this also gives a list of other bikes it fits hope this helps. Edited June 21, 20188 yr by NE0
June 21, 20188 yr Moderator There you go :- https://www.ebay.co.uk/itm/YAMAHA-RD125LC-10W-13W-1GU-55K-GENUINE-SWING-ARM-SHAFT-PIVOT-4V0/263768816708?hash=item3d69d8bc44:g:gRgAAOSwXudbF39v
July 13, 20188 yr Author 4 hours ago, NE0 said: Nice, ....especially the brown carpet!? That's my kneeling pad in the garage - not in the lounge ?
