FJ1200 3CV new chain + sprocket advice
DutchFJ1200
This post is 2375 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
Morning gents,
I know nooby question but you never know what the brain-trust here can advise.
Been a while since I changed sprockets & chain and forgot which ones I ordered from Wemoto a few years ago. https://www.wemoto.com/bikes/yamaha/fj_1200_3cv_type/88-90
There are 6 options and price wise not too much in it.  Is the most expensive at £147 simply the best ??
Also I seem to remember reading here that there may be an option to change the sprocket ratio to have less revs at high speed/better fuel consumption. I'm aware you lose a bit of bottom end but that's not too important soo, what's the skinny on this?
I do quite a bit of dual carriage way miles lately commuting and at a ton I'm doing 6/6.5K revs. and you can see the fuel gauge go down. (okay.... I had a play with a Porsche Panamera yesterday and we went considerably faster than that which didn't help the cons. much. :lol:)
Fire away.
My bikes are not quite in the same league chain wise but for what its worth. I go with the standard did chain.
All the fancy bullshit comes to nowt in the real world.
Top of the line is 120+ the standard chain 27, ask yourself this (I know you have to have softlinks where I can cheat with splits) will the 120 quid chain last 6 times longer than the standard units. Even their own bull says it outlasts standard chains by 40%.
Little bit extra lube time and save a chunk of change? At the very most I would only go with the basic O ring.
  • Thanks 1
I've got the X chain via Afam and found it really durable. think i've adjusted it twice in 3k
  • Thanks 1
I'd just go for DID X ring, gold if you want a bit more bling.
Sprocket wise 1 tooth bigger on the front should get you what you want.
Sent from my SM-G950F using Tapatalk
  • Thanks 1
Hello chaps,
Ordered 1 tooth + up on the front, standard on the rear and the silver/black X-ring. The gold was not in stock.
Put the lot on today, look forward to see what that one tooth + front feels & does.
Hello chaps,
With your torquey beast you'll probably only notice it at the pumps
