No indicators or horn
Hi all hope this is ok to post here I'm a new member I've got a 1993 Yamaha yzf750r out of the blue the indicators stopped working except the rear right also the horn has now stopped working all other lights still work I've put a new relay in checked fuses and for brakes in the wires can't find anything as anyone on here had a similar or same problem?
Thanks in advance
You really should pop an intro in the new members area, bit of netiquette.
Bulbs good?
Bulbs good?
Hi have done now and yes all the bulbs are fine when I alarm the bike all the indicators flash getting power from the flasher relay also
LOL,
There is your answer, the alarm is faulty or its connections have worn/weakened , check/remove as you please and even money it fixes it. Alarms are notorious.
2 hours ago, Cynic said:
LOL,
Cheers for the reply will have a look in to the alarm side of it
