May 16, 20187 yr Hi all hope this is ok to post here I'm a new member I've got a 1993 Yamaha yzf750r out of the blue the indicators stopped working except the rear right also the horn has now stopped working all other lights still work I've put a new relay in checked fuses and for brakes in the wires can't find anything as anyone on here had a similar or same problem? Thanks in advance
May 17, 20187 yr Moderator You really should pop an intro in the new members area, bit of netiquette. Bulbs good?
May 17, 20187 yr Author 3 hours ago, Cynic said: You really should pop an intro in the new members area, bit of netiquette. Bulbs good? Hi have done now and yes all the bulbs are fine when I alarm the bike all the indicators flash getting power from the flasher relay also
May 17, 20187 yr Moderator LOL, 2 hours ago, Python666 said: when I alarm the bike all the indicators flash There is your answer, the alarm is faulty or its connections have worn/weakened , check/remove as you please and even money it fixes it. Alarms are notorious.
May 17, 20187 yr Author 2 hours ago, Cynic said: LOL, There is your answer, the alarm is faulty or its connections have worn/weakened , check/remove as you please and even money it fixes it. Alarms are notorious. Cheers for the reply will have a look in to the alarm side of it
