May 9, 20188 yr Hi guys n dolls, I'm new on here so be patient please, I unplugged the outside temp sensor on my Tracer to move the tank slightly and forgot to put it back on initially, after starting my bike the engine management light came on and after replacing the temp sensor plug it's staying on, does anyone know the resetting sequence please as the main dealer wants to take one of my legs or arms as payment, Many thanks Rich
May 9, 20188 yr I've had a look on Google, and found the owners manual (which you probably have) pages 3~11 detail the dashboard but there's no mention of a reset procedure. If its anything like a car, the system has an ODBC connector and the error is stored in memory requiring it to be plugged in to clear and reset the memory. I also found this on a website for the same error but on a FJ-09 and the reply was and seems to confirm it..... Quote Finally got it in to the dealer to straighten this out. The tech confirmed that the only way to turn off the light is by plugging it in to a computer running Yamaha diagnostic software and checking/clearing the codes. He said there were only two "historic" codes that came up one being a "stall" and the other being "front wheel ABS sensor". He couldn't explain why the check engine light remained on being that these weren't "Active" codes. Either way he cleared the codes and no more Check engine light the above from https://fj-09.org/thread/5723/2017-reset-check-engine-light So in a nutshell, no i don't think there is a 'user' way to reset it.
May 9, 20188 yr Author Thats great Neo, thank you very much for your help and digging out for me, much appreciated and it looks like the dealer gets another leg or arm, Thanks again Rich
May 12, 20188 yr Moderator Just a thought, (my stuff is waaaaaaaaay to old) if were talking standard obd2 stuff you can download the software and get the cables for your lap top for not a lot of cash. The obd doctor i have to fix the wife's car only cost 30 quid. The forscan for the Mondeo was 12, with the cable. Useful way to get a good quality odb2 cable is to buy the forscan unit anyway rather than a cheap chineese cable. Not saying it does work, i haven't tried it on a bike but it has so far worked on Renault, Nissan, and BMW. Must be worth investigating.
May 12, 20188 yr A little bit of ebay searching and google searching brought up this..... https://www.ebay.com/itm/Yamaha-OBDII-OBD2-MT-09-MT09-XSR-900-FJR1300-MT10-MT10SP-R6-MT07-XSR700/142784680925?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D44040%26meid%3Defec2d612d944c6e9e91d1f12b6160a5%26pid%3D100623%26rk%3D2%26rkt%3D4%26sd%3D252780397410%26itm%3D142784680925&_trksid=p2047675.c100623.m-1 But it does also mention a 3 pin and 4 pin connector depending on year. This cable ONLY provides the ODB2 connector socket nothing more! You do of course still need to have a some form of scanner/laptop and an interface tool as mentioned by Cynic.
