May 4, 20187 yr I have this strange issue with the clock: in March the clocks went forward 1h for daylight saving but I didn't fix the clock on my MT125 so it was 1h late (e.g. at 6 the clock would say 5). The other morning I picked the bike and the had gone 2h forward ?, e.g. at 6 the clock would say 7. Does the clock adjusts itself?
May 4, 20187 yr Hi Ivano. Welcome to the forum. Unless your bike is connected to WI-FI or a sat nav I can assure you that unless you adjust the clock manually it will not "self adjust". You say "The other morning I picked the bike and the had gone 2h forward ?, e.g. at 6 the clock would say 7." Who did you pick your bike up from? Maybe they adjusted the clock for you, just a thought. Mike
