April 13, 20187 yr Hi. I am trying to get the bike back on the road, after rebuild it the headlight dosent work as there isn't any power getting to it, can anyone tell me which cable should take the power to the headlight . Thanks.
April 13, 20187 yr Moderator Hi Pete, you do know the engine has to be running for the headlight but not for the pilot light? Ignition key posn 2
April 13, 20187 yr Author Thanks for replying ! I thought the headlight worked when the engine wasn't runing, just off the battery ?
April 13, 20187 yr Its 6Volt a/c Lighting pete,, ,a little 6 volt batery would be dead in seconds on D/C, the bulb wiring should be Green- dip Yellow main beam, and black earth, ,,
