78 dt 175 lights
Hi. I am trying to get the bike back on the road, after rebuild it the headlight dosent work as there isn't any power getting to it, can anyone tell me which cable should take the power to the headlight . Thanks.
Thanks for replying ! I thought the headlight worked when the engine wasn't runing, just off the battery ?
Its 6Volt   a/c Lighting pete,,  ,a little 6 volt batery  would be dead  in seconds on D/C,     the bulb wiring  should be  Green- dip  Yellow main beam, and black earth, ,,  :welcome:
What was the problem?
