81 xj550 Maxim starting/running problems
Help needed please, when bike is turned on it fires, but if it doesn't burst into action it has to be left 10 minutes before it will fire again. Could this be a diode problem. When it does run engine seems fine but number 2 exhaust runs considerably cooler than the others.
How long has it been sitting ,  i would change the fuel,,  , then plugs, :welcome:
If it ain't hot then it's not firing, simple things first as above plugs then HT leads then fuel.
It was laid up for 2 years. Carbs cleaned ultrasonic,new pilot jets, new fuel. Valve checked ok, compressions checked ok. Leads changed from one side to other but number 2 exhaust remained considerably cooler. Firing problem seems electrical as if left for 5-10minutes it will fire again.
