Hi,
Anyone successfully upgraded the YBR headlight from its factory fitted shy 'glowworm'?  I have looked at a few things on Google but no definitive solution.  I did put a larger watt bulb in it before the bike got stored and this helped but it occurs that an LED should be able to pump out a bit more light without melting the wiring or draining the battery.
I did find the link below but not sure what folks think
https://www.ledperf.co.uk/led-bulb-kit-for-yamaha-ybr-125-2010-2013-motorcycle-p-26460.html
I also thought about adding a couple of ancillary lights powered direct from the battery and switched by a relay from the headlight (or an ancillary switch)
Any thoughts or advice appreciated
