1999 Yamaha SR125 - Potential Sticking Clutch Plates?
Hi guys!
Having a bit of a "problem" when trying to put my bike into first gear from idle during a cold start. The engine starts usually pretty well (occasionally cuts out during idle on a cold day), but when I get onto the bike and try and put it into first gear....the engine cuts out. I have to repeat this process maybe 1 or 2 more times before it eventually works and I can ride off. I know the Yamaha SR125 has a side stand cut off trigger (caught me out before!) so I could investigate that switch. However because it eventually goes into first gear after a while when the engine is warmer makes me believe its a clutch problem.
Thanks guys!
Yeh ,change the oil,.   and maybe adjust it at the bars,,,, if its too loose a lever,
Sometimes with the lil puddlehoppers people go veeeery long on oil changes or use the nasty pound shop or forecourt stuff.
Some proper motorcycle engine oil will make a difference. Even if it isn't the issue and its not nearly expensive enough to skimp on either.
