YBR 125 Fault codes 12 & 33
Hi Everyone,
(newbie here and glad to be here)
I was wondering if anyone has rectified the following fault codes :-
12 (Crankshaft position sensor)
33 (Igntion Coil)
I have checked for and breaks in the wires etc and have repaired any that needed it, however I still can’t get the bike to start. I have checked the igntion wires black/black and white and jumped these across but still won’t atart.
any ideas ?
thanks
Well if both those things are bosted you'll never get it to run. However I'd say it's unlikely that both components would break at the same time.
Do you have a wiring diagram? I'd be looking for a common connection between the 2. I'm assuming your battery is in good nick and fully charged?
Does the engine turn over off the starter but not fire?
Yup, got the diagram.
yeah the battery is fully charged and the starter try’s to turn it over but there’s no spark at all to the plug . .
UPDATE
Ive checked the crankshaft position sensor and has 268ohms resistance so all seems good there ?
