yamaha sr switch gear wiring
I ve noticed a lot of yam switch gears use the same wiring can anyone advice me on this I want to use the sr switch gear on the dt loom the switch gear has these wires
black . pink  these are horn
dark brown . brown/white . dark green  these are indicators
green .yellow  these are lights hi an low
brown .blue on off for hazards I think ?
the dt has a yellow wire with a redstripe this is power from the cdi to the dt  headlight switch do I need to wire this to the sr switch above or can I use a brown (switched live from the dt loom)
was thinking if I could run the yellow red to a light on the dash an that way if the cdi ever played up the light would go out
