Posted August 31, 20178 yr Thanks I need some advice I got a tzr50 I need a airbox and my oil and temp light stays on wen the engine is running and oil is full
September 4, 20178 yr Hi Phil First thing you need is a workshop manual then replace the oil pressure switch or just check it wiring, the location of which will be in the manual.
