Posted August 17, 20178 yr Can anyone help me!? I can't get my dragstar 650 classic started anymore. I know it's a fuel problem because no fuel is getting into the carburetors. It's turning over but engine just won't fire. I have replaced the fuel, the fuel filter, the oil, the oil filter, the air filter, the fuel pump relay, the battery, the spark plugs, and I've had the carbs professionally cleaned. I've also tested the fuel pump by connecting it straight to the battery and it worked. None of the fuel lines seem blocked either. im running out of things to replace thanx!
August 18, 20178 yr Have you checked the fuel tank tap to make sure 1. that its turned on, and 2. that its letting fuel through when its turned on. And you will find that you will get more help if you post an intro in the new members section first.
