Can't figure out compression problem -2 stroke HELP!!!
I have the same problem aerox ns50 70s full kit all new gaskets new crank and seals
Piston cylinder and head with new rings came as a set shows 60psi has good spark but wont fire carb is off another rox that works fine but still wont start
This thread is 2 years old, you need to start your own to get a fresh view. put as much info in as possible.
