one pot xs400
Hello
Can anyone offer a likely cause for a problem with my 1984 XS400 dohc. It starts on just the left cylinder until it's warm(ish) when the other cylinder cuts in. Only clues are that I can't check the plug as it's stuck (don't want to force it until I know where to go next) but connecting a spare plug shows it is sparking. It runs and starts perfectly when warm. Any suggestions much appreciated. Thanks CEG.
Hello
difficult one.....
maybe a valve seal leaking causing oil to run into the cylinder. after a bit the oil is passed through the exhaust and the petrol can ignite. When warm the oil hasn't got time to drain past the seal.
do you need to top up the oil level much?
Are the valve gaps correct?
you need to do a compression and spark plug check, get yourself a helicoil insert first before you take the plug out. Then your covered
difficult one.....
Thanks a lot. It doesn't appear to be using oil (I only use the bike occasionally) but you've given me some ideas to look at. Cheers. Colin.
