July 1, 20179 yr just bought a yamaha virago 125 and its wont start and there no spark going to spark plugs i bought new ones just can find the problem the electric start works just the bike wont turn over to start
July 1, 20179 yr Hang on a sec, You say the starter works then say it won't turn over, which is it? Or is it that it turns over but won't start cos if it's that then your going to have to explain some more cos there's not enough info there to make any kind of even wild guess why it won't start. Have you checked there is fuel to the cylinders? The electrics on these are complex even for a little bike so do you have the manual? If not then that's where you should start. Not having a pop at you, there is just not enough info to go on, we like to help but you have to explain in detail what's not happening and what you have done so far. Also it might help if you say hello in the New members section cos one hit wonders usually don't get much in the way of replies. Just sayin..! Oh and see about filling in your profile while your at it as there might be someone nearby who could help out.
July 1, 20179 yr Hi Jake, and welcome to the forum. As Slicey boy said. Also it might help if you say hello in the New members section cos one hit wonders usually don't get much in the way of replies. Just sayin..! Oh and see about filling in your profile while your at it as there might be someone nearby who could help out. So, are we going to hear from you again? I hope so but I doubt it. Mike.
