Seat/steering Locks
Hello All.
I have an 1976 RS 125.
Both the steering and seat locks are damaged, but I have the original Key.
If I get replacement locks, is it possible to remove the original lock barrels and replace these with the new locks so I can keep the original lock and not end up with two or three different keys.
I have stripped the original seat lock down, but cannot work out how to remove the barrel.
How do you remove the original barrel?
Thanks.
A good locksmith may be able to help
This tells you how to get the keyway out of the ignition block to help with the broken steering lock, you buy a replacement keyway and refit it to the original lock.
