dt125r rear shock
This post is 2658 days old and we'd rather you create a new post instead of adding to this one. You can't reply in this post.
i have an 02 dt125r and a work friend of mine has an 07 dt125sm, i was wondering if his rear shock and mine are both the same as his feels a lot firmer when you push the seat up and down, we have looked underneath and the preload/adjustment nuts are virtually in the same position but there is definately a difference as his feels firmer and mine feels as though it has a more smoother through action. both the rear shock springs are red
Different shock on the SM versions. Made by Sachs
It's a straight swap but good luck getting hold of one. I ended up fitting a shock from a R when I rebuilt my bike.
You might be better off going aftermarket, YSS do one for the DT.
