June 4, 20178 yr Hi All Yam fans I am hoping someone can resolve this one I have Just bought a dt175mx and have found when I pull away the clutch is grabbing on and off as I release it and its bloody awfull.I have changed the friction plates and Springs And it still does it. Any ideas lads and lasses would be appreciated.
June 4, 20178 yr Moderator Did you check the basket for ridges, did you smooth them off, did you take the sharp edges off of the friction plates when you got them before soaking them in oil for a few hours.
June 4, 20178 yr Author Hi cynic yes I did check the basket for ridges,the friction plates are new and were soaked for 24 hours. the bike seems to judder as you release the clutch then grabs .also the clutch cable is new.
June 4, 20178 yr Was it like that when you bought it? Was it from a dealer? If it was, then take it back
June 5, 20178 yr Is it a jumpy feeling when pulling away?My 175mx did this with new metal EBC clutch plates and replacement used basket as I had clutch rattle with the rivets. Im considering changing it back to the Cork plates and old basket.
