May 28, 20178 yr Help needed...! When splitting the cases to fix a slipping starter clutch.. where are the bolts #s 21, 22, 23 hide.. I hoping not under the head!! If so any quick way to compete as i do not want to dissasemble the cams/valves.. Sent from my SM-G930F using Tapatalk
May 28, 20178 yr Author Found them....[emoji35][emoji35] What was yamaha thinking ???? The whole topend had to be removed... Sent from my SM-G930F using Tapatalk
May 28, 20178 yr What they were thinking Andrew was, by the time you need to do this it won't be our problem. Anyway mate you've done a good job so far, just keep plugging away and it will all be over before you know it.
May 28, 20178 yr Moderator It may well be one of those carefully engineered problems. It wont fail in the warranty period, not for several years, but when it does you either pay through the nose to fix it at a dealer or buy another bike. Win win.
